SailNet Community - View Single Post - What Spare Parts Do You Carry Aboard Your Boat??
post #22 of Old 06-05-2008
Maine Sail
Maine Sail's Avatar
C'mon dawg..
I'm way overkill..
Imperlers-2
Gaskets-3
Oil Filters-1
Primary Fuel Filters- 2 - 10mic and 2 - 30mic
Alternator
Secondary fuel filters - 2
Alternator belt - 2
Water pump re-build kit - 1
Hose Clamps - many assorted sizes
Radiator hose in each size used on engine
Solenoid - 1
Air Filter -1
Zincs -3
HX gaskets -2
14lb. Radiator Cap -1
Tranny Fluid 1 gal
Oil 2 gallons
Oil Absorbing pads - 20+/-
Thermostat - 1
T-stat gasket - 2
Temp gauge sending unit -1
Coolant 1 gal
T-handle for Racor in case vacuum gauge fails
Fuel line
Strainer basket for Sea Strainer
Shaft Zinc -1
General
TefGel
Sika 291
Zipper Lube
Silicon Dielectric Grease
BoeShield
McLube
GooGone
Magic Eraser
Rags - 40 terry cloth / 20 Microfiber
Assorted Stainless Fasteners
Clevis pins - assorted
cotter pins - assorted
Shackles - assorted
O-Rings - about 60 assorted sizes
JB Weld
Batteries AA, AAA, D, C, 9V
Electrical tape
Zip Ties - assorted
UV Duct Tape
DevCon Plastic Welder
Velcro
Heat Shrink wiring connectors
Adhesive lined heat shrink tube
Nav bulbs
Interior bulbs
Terminal strips - assorted through 10 space
Fuses various sizes
Plumbing - large water prrof container of fittings
Wire 10-2, 12-2, 14-2 about 25 feet each
Rigging Blocks etc. - large waterproof container
Canvas repair stuff - buttons, twist locks etc.
Sail repair kit
Whipping line
Monel seizing wire
Domestic water filters - 2
Britta Faucet Mounted Filters - 2
Wet Suit
Dive Hat
Knives
Mask
Flippers
etc. etc..
God I need to stop this stuff is worth more than my boat...
Always close your organizers!
______
-Maine Sail / CS-36T
Maine Sail is offline
