SailNet Community - View Single Post - Chick Tips!
Thread: Chick Tips!
Old 06-08-2008
NauticalFishwife NauticalFishwife is offline
NauticalFishwife is on a distinguished road
Send a message via AIM to NauticalFishwife
Chick Tips!
I thought it might be fun to share tid bits of ideas we ladies have come up with. After all, it's usually the little things that make us smile. It can be anything from time saving tips while cooking in a hot galley to sewing tips. Here's one ... I don't consider myself as overly modest. You really can't be if you shower in marinas without private showers. You step out of the shower and dry off, then wrap the towel around you. And you know how it always falls off as soon as you raise your arms?! After you use your wide tooth comb to untangle your hair. Then use the comb as a clip to hold your towel. Overlap your towel around you then, slip the comb, between two teeth at one end of the comb over the towel -then again at the other end of the comb. It clips your towel around you while you primp!
"The God's do not subtract from man's
(or woman's) allotted time the hours spent in sailing."
Martha
Calypso-Dickerson 37
