SailNet Community - View Single Post - Barient winch
Thread: Barient winch
post #3 of Old 06-08-2008
L02314564
Itz That Eazy!!!
L02314564's Avatar
Originally Posted by anderbra View Post
So this morning I was hoisting my genny (with pendant installed) to go for a sail, when the halyard winch locked. So I disassembled the winch and I found a broken cotter pin jammed in the gear.
I look around and see only one place where it could have been. However, when I placed a new pin, the whinch would not work.
The winch in question is a Barient 18, installed on the mast.
Does anyone has an exploded view of this (or equivalent) winch that shows where a cotter pin should be placed?
Thank you for any help on this issue. BTW, I even forgot I was going sailing.
Not exactly sure about the cotter pin for a Barient 18, but there is one that is used to retain the IDLER GEAR SHAFT to the main base on the 27. I don't have an exploded view for the 18, but this link will give you views of several winches in the 18 range. Hope it helps.
http://www.ewmanchester.com/CalDocs/...ts-Service.pdf.
Edward
U.S.A.F. Retired
S/V Itz That Eazy!!!
1976 Catalina 27 #2684
L02314564 is offline
