Found a nice way to make this a one man job. Use a hack saw to cut a notch into a nut of the same size as the one on your bolt. From below put this nut onto the bolt and clamp it with vise grips. this will keep the bolt from spinning. you can then hold the bolt still, and twist the holding nut with another wrench. works nicely.
