Old 06-09-2008
T37Chef's Avatar
T37Chef T37Chef is offline
Senior Culinary Member
T37Chef will become famous soon enough
Lightbulb Some classics...
You said impromptu happy hour...so that means items that should be something you would likely have on-board all the time, and require no cooking...right?
That's a tough one considering the criteria...
especially if you don't have 24 hour refrigeration on-board like myself. Even if you do and your a weekend sailor you probably don't leave much more on board other than condiments & beer. Maybe some cheese's, and things like crackers & nuts? I can't think of much other than that...but if your willing to do a little planning ahead...most of the following require no or little cooking and assembly:
  • Caprese Salad: Sliced Tomato & Fresh Mozzarella topped with basil, serve on/or with Olive oil, balsamic, and bread/toasted bread. Easy!
  • Prosciutto & Melon: Cantaloupe wrapped with prosciutto ham, easier to eat if you put em on a toothpick
  • Ceviche: Fresh fish or shellfish, marinated with citrus
  • Carpaccio: Raw Beef/Lamb usually a tenderloin or loin cut, sear outside if desired, chill, slice thin, thin, thin, serve with capers, sliced onion and a mustard mayonnaise and toasted bread or the bagel chips mentioned.
  • Belgian Endive with Smoked Salmon: Puree or chop the smoked salmon and mix with your cream cheese/marscapone cheese and spoon/pipe on the bottom end of the endive leaf, top with chive if your so inclined
  • Fig & Walnut Bruschetta: Soften some blue cheese, spread on some toast, top with a half of fig and some chopped walnuts
  • Cucumber Tea Sandwich: Spread white/wheat bread with dill flavored butter (both pieces), peel & slice cucumber and lay on bread, top with bread, slice crust off to form a square, then cut on diagonal to make 2 or 4 triangular mini tea sandwiches. Very light and refreshing bite!
  • Smoked Trout with horseradish dip/spread & crackers.
  • Charcuterie(sausages, salami, pate's terrine's) Platter serve sliced with cornichones. Buy at your local butcher or specialty shop, can be expensive and hard to find quality in some area's. Wegmans has some good stuff.
Just a few things that I could think of at the moment...will edit as them come to mind
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
