SailNet Community - View Single Post - Bought a furler - Install tips?
post #3 of Old 06-09-2008
sailingdog
Are you replacing the forestay? If not, you probably should be, especially if it is more than five years old.
Dry fitting the pieces or at the least, laying them out and making sure you have a good idea of what order they assemble in is a very good idea. If you have to cut the foil to match your forestay... measure twice, if they don't match... measure again... then cut. If in doubt, cut it a little long, since you can always trim it a bit more. It is a bit harder to stretch the foil if you're a bit short.
sailingdog is offline
