SailNet Community - View Single Post - rebedding stanchions
post #24 of Old 06-09-2008
Maine Sail
Maine Sail's Avatar
Originally Posted by Freesail99 View Post
The key word here is access permitting. As far as using a rechargeable impact driver, good luck in keeping the screw driver in the slot on the bolt, up top. Most of the bolts have a slotted head.
I do this from under the deck on the nuts not from the top on the screws. So far, with ratchet extensions and or knuckles, I have been able to reach each and every stanchion base on my boat and re-bed every single one with only the impact driver and no screw driver or wrench is used on deck..
The whole point of me using the impact driver is it makes it an easy one person job without having to use Gorilla Tape and a pair of Vise Grips...
BTW if an impact driver will not fit, a pair of needle nose Vise Grips and Gorilla Tape will. Simply taping the vise grips to the underside of the deck, clamping the nut, with this tenacious tape has worked every single time for me.. Quick and easy but not as quick and easy as an impact driver..
______
-Maine Sail / CS-36T
Maine Sail is offline
