SailNet Community - View Single Post - Repairing a rotten bulkhead..
Old 06-12-2008
sailingdog sailingdog is offline
SVDS-
Yes, you can scarf in a new piece and then fiberglass it to the hull and remainder of the bulkhead and if properly done, it should be strong enough to handle the loads of the chainplate. However, IMHO, I think replacing the entire bulkhead makes for a stronger repair, but is a lot more work. It shouldn't be too bad though, since it appears that the port side is completely separate from the starboard side... so you'd actually only be replacing half a bulkhead.
