SailNet Community - View Single Post - Repairing a rotten bulkhead..
Old 06-12-2008
hellosailor's Avatar
hellosailor hellosailor is offline
Not being a structural engineer but having had some real-world experience with breaking things...
I don't think I'd trust a scarfed-in repair. Sure, you could cut out an oval of new wood or fiberglass board that was a foot or so across (no corners, fewer stress concentrations) and then just replace the area where the chainplate bolts in. But all the stress is now being put on the edge of the join, which is what? 3/4" or inch thick bulkhead? Given some lateral movement forward or aft, I'm not sure how well that would hold.
If I did it that way, I think I'd want to sister up overlapping larger plates, with a good 6" overlap, on both sides of the bulkhead. Wood, fiberglass board, or bronze or stainless plate, any one of them, just to ensure that the "plug" couldn't pop out of the bulkhead. All through-bolted together as well as epoxied.
The alternative is replacing the whole bulkhead, which structurally and aesthetically is probably the only right way to go. But a lot of work, chewing out the old bulkhead, slicing clear whatver they've joined to it "forever", replacing that all again. Some of those nice Japanese hand saws, a bit of molding...and maybe a week or two working with your best friend?
Congratulations on the paid off! And just what IS the boater's equivalent of a mortgage burning ceremony anyway?!
