  #20 (permalink)
Old 06-12-2008
Maine Sail's Avatar
Maine Sail Maine Sail is offline
More info..
Free sent me a PM and I though this was good info to have in the thread.
Originally Posted by Freesail99 View Post
How did you use the butyl tape on the genoa tracks or the traveler? Did you apply it in strips ? My tape is 3/4 and 1 inch wide.
I never re-bedded the track on this boat. It's 29 years old, original and BONE DRY! The track is mounted through a solid glass portion so I'd spot a leak in a split second as there is no core for the water to absorb into.
I have used butyl tape on other boats and here's how I do it and some things/tips I've learned along the way:
#1 Clean the track and make sure it is of the concave bottom type. If it's a flat bottom buy a new track. The concave bottom is designed to capture bedding compound.
#2 Wrap the area where the head of the stainless bolt will hit the aluminum track to prevent galvanic corrosion.
#3 Insert the bolts into the track holes after wrapping the heads and flip it over.
#4 Apply enough strips of butyl tape to the under side of the track to be 1/16" to 1/8" proud being very careful to get good coverage around each bolt. Cut the tape on a plastic kitchen cutting board with a razor blade using a downward "cleaver chop" and not a "pull" through slice as this stuff will stick to the blade as you do a "pull through" slice as opposed to a chop or "cleaver" type slice.
#5 Wrap rings of butyl around the threads of each bolt and as close to the track as possible and mold the to a cone style as I showed in the other post.
#6 Thoroughly clean the deck ESPECIALLY IF SILICONE WAS USED!!
#7 Countersink each hole very slightly using a countersink and REVERSE on your drill. Using forward will make the hole way to big if you are not careful. Contrary to popular belief countersinks work wonderfully, for detail work in fiberglass, in reverse and you won't chew through the deck in.002 seconds while having an ADHD moment..
#8 Set the track over the holes and push down slightly and evenly just until the butyl starts to compress.
#9 Go inside the cabin and install the backing plates/washers and make finger tight only.
#10 Do one more even pressure by hand, above deck, using a 3' straight piece of lumber helps, and then do another finger tight.
#11 Very carefully, and with a short 0.25 second burst, hit the nuts with an even amount of impact wrench. Then wait about five to ten to twenty minutes, depending on outdoor ambient temperature, and hit it again with the impact wrench. Repeat this procedure/waiting regimen until the track is tight to the deck and the butyl has squeezed out. DO NOT over tighten the butyl to quickly! This stuff is as thick as gorilla snot and can literally bend a genny track between the bolts if tightened down to fast. Gentle pressure applied over a period of time with give the best seal.
Once done peel the excess butyl away. One trick I like is to make a ball from the excess and use it to dab up stray butyl. This works very well around the fastener heads in particular.
One other option is to use TefGel between the bolt head and genny track and then butyl cones on the underside. It works well both ways..
______
-Maine Sail / CS-36T
