SailNet Community - View Single Post - Diesel Tank with no Fuel Return
post #3 of Old 06-13-2008
christyleigh
christyleigh's Avatar
After thinking more on it maybe you would be OK to vent and return from the tube if you only used one tank at a time exclusively. My thinking was from my dual tank setup that I have a Filter Boss polishing system set up so I can run from either and return from either with setup switches.... or... polish from either and return to either with setup switches. That's why the first thought that came to my mind was taking fuel out of tank 1 while returning to tank 2(your no return tank) which would definitly give you a (bubling) problem at the vent which would be trying to vent Out to make room for the fuel comming In to tank 2 whether running or polishing.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
