  #20 (permalink)
Old 06-13-2008
sailingdog sailingdog is offline
A better alternative to a solid fiberglass bulkhead is to make a cored bulkhead, with solid laminate in the sections where the chainplate fittings are. That would be lighter and stronger than a plywood bulkhead, yet as rot-proof as a solid-fiberglass bulkhead. It would also be fairly easy to make in whatever size you required, and piecing sections together to make the entire bulkhead would be rather simple.
