Old 06-15-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
If you're going to be painting the interior of a boat, you'll probably want to prime the fiberglass and wood. As LLVS said, prep work is the key to a long-lasting paint job. In most cases, the prep work is the bulk of the work, not the actual painting. Be careful if you choose to use a two-part polyurethane paint, as the catalyst in them is cyanide-based and probably requires you to wear a good respirator if working in an enclosed space like a boat.
Be aware that glossy paints tend to last longer and tend to be more durable, especially in a marine environment, and are often easier to clean and maintain.
If you're new to the Sailnet Forums... please read this POST.
Sponsored Ad
