SailNet Community - View Single Post - Drilling for Oil in the Bakken formation
  #133 (permalink)
Old 06-19-2008
Cruisingdad's Avatar
Cruisingdad Cruisingdad is offline
Best Looking Moderator
Cruisingdad has a spectacular aura about Cruisingdad has a spectacular aura about Cruisingdad has a spectacular aura about
Originally Posted by teshannon View Post
CD,
Here's some numbers for your alternate energy source, in this case wind. A while ago I was asked to do a quick look at using wind power to replace 1400MW of nuke power. Nothing fancy, just a quick assessment.
The current wind generators are rated at anywhere from 1/2 MW to 2 MW. Manufacturers are promising 5 MW generators in the future, so I used 5. They only have an efficiency of 30% at best so I used that. At 5MW and 30% efficiency you would need 960 windmill towers. They require a minimum of 5 rotor diameters separation between them and rotor diameters are about 433'. If you do the math that equates to about 472 miles of windmills just to replace one large nuke. If you used todays size generators it would more than double that. If you put the windmills in a farm pattern you would need in excess of 13,000 acres! And none of that counts the space required for the storage batteries that don't exist today to store the energy for when the wind is not blowing.
I'm for drilling for oil now, no matter what the quantity - and hey, what about coal.
I have better numbers than that. I will show them.
By the way, who told you I was against nuclear or coal?
I am about what makes sense... drilling for oil does not. You also might want to check your numbres about the amount of oil used to supply energy to homes. It is not the percentage you think it is. Much of it comes from coal.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
