SailNet Community - View Single Post - Fiberglassing Over Hull Deck joint?
post #3 of Old 06-23-2008
sailingdog
Might want to make sure that you get the thickened epoxy well into the joint. Those 100 screw holes are for bolts that are providing a major part of the strength of the hull-deck joint. Glassing over the join will do a good job of sealing it, but if the join isn't epoxied together, the loads on it might be a problem. Ideally, you should fiberglass over the interior of the hull-deck join as well.
sailingdog is offline
