SailNet Community - View Single Post - O'Day 23 boarding/swimming ladder
post #1 of Old 06-25-2008 Thread Starter
svey
I'm installing a boarding/swimming ladder on my 1976 23' O'Day. I drilled 2 holes yesterday on the transom 20" from water level (starboard side). To my surprise, it doesn't look like I've gone through any core material. Just the 2 layers of GRP. Is it possible that the core material doesn't go that high? I know there was balsa on the starboard side lower section where my motor lift is installed because I had to tear and rebuild that portion because of water intrusion and rotten balsa.
Now for the big question, how can I install the ladder? I've made a 14" x 5" stainless steel "washer" for the outside portion and 2 6" x 5" "washer" for the inside. The right bracket falls inside the cockpit bench/locker so I will build a large GRP backing plate with epoxy and mat to distribute the weight. But how can install the other bracket if there is not core material?
svey is offline
