SailNet Community - View Single Post - Plumbing a 2d Bilge Pump
post #4 of Old 06-25-2008
sailingdog
If you're really against installing a new through hull for the second pump, you could always plumb it so that it drains into the cockpit, and out the cockpit drains. Of course, if your cockpit drains use hoses and they fail, this will tend to screw you royally... but you can't have everything.... It is just as much work to install a through hull as it is to have the bilge pump drain into the cockpit, so just do yourself a favor and install a through hull instead.
sailingdog is offline
