SailNet Community - View Single Post - At anchor in heavy weather
post #2 of Old 09-23-2003
Silmaril
You are correct about having the elasticity help the anchor, but it also helps lessen the shock loading on the vessel as well.
You should make up a length of line, stout enough for your vessel, that is about 1.5 times your boat length. Use about half as a snubber, and attach to your chain with either a claw or a shackle. Then tie that off to your boat. The reserve length will be good if you have to adjust your scope and not have to re-attach the snubber.
My ground tackle is not as sophisticated. I have a 35# CQR with about 25'' of proof coil chain, attached with a shackle to 200'' of 5/8" 3-strand nylon rode. The secondary anchor is a 10# Fortress with 10'' of chain and 200'' of 1/2" 3-strand nylon. All that for a 37'' boat with low windage and weighing about 11,000#.
While I have not anchored in a huricane yet, I have been able to sleep through just about everything else.
Silmaril is offline
