SailNet Community - View Single Post - Harder to pull than expected
post #6 of Old 07-01-2008
sailingdog
David-
First of all, you should never pull on a line that is run through a self-tailer, as this will abrade the line unnecessarily and shorten its life drastically.
Second, even though you've only gone from a 27' boat to a 30' boat, the size difference is quite a bit more significant. A Catalina 27 standard rig displaces 6400 or so, the Catalina 30 10000, or 66% more. While the 3' doesn't sound like much of a difference, the boat is increasing ind beam (10.83' vs 8.7') and depth as well.
As pointed out previously, the increase in difficulty is pretty much due to the increased sail area. If you reefed the headsail down to the same area as your Catalina 27 had, you'd probably be able to haul in the line without removing it from the self-tailer or using a winch handle.
Originally Posted by davidpm View Post
Last year I sailed a Catalina 27 this year a Catalina 30.
Last year I noticed I could leave the jib sheet in the self tailing clamp and just pull it and I could pull it in no problem.
On the 30 I have to either take it off the self tailer or put it in the self tailer and use the winch handle.
Same thing for the main sheet. On the 27 I would only use the handle in the heaviest air.
I just had the winches serviced and put on new sheets.
Is this to be expected because it is a bigger boat? Maybe something else is wrong. Blocks seem OK, sheets are clear. Don't know what else to look at.
Frankly the 27 was a lot easier to sail.
The jib is about a 150.
sailingdog is offline
