Old 09-26-2003
e31 e31 is offline
e31 is on a distinguished road
Lewmar opening port leak
When I strip out a hex drive feature I usually find it quickest to cut a slot in the head with a dremel cutoff wheel (or file is you don''t have a 12V dremel or inverter)sized to a big flathead screwdriver. Turn out the old screw and throw away.
I''ve found that phillips head strip less often so I slowly and changing out the slotted heads as I work away on each project.
Doug
