SailNet Community - View Single Post - Replacement sails - Hood''s Vektran
post #5 of Old 09-26-2003 Thread Starter
paulmcquillan
Replacement sails - Hood''''s Vektran
Condition of the main...
ProspectiveSailmaker asked for digital photos taken from under the boom. In the meantime, here''s what we saw.
When viewed from below, the deepest part of the curve, going upwind in 9kts TWS, appears to run from the head of the sail to a point 48 to 50% of the sail''s foot length.
Viewd from below on the leward side, the main shows a fairly broad full area at least 1.5x the boom width. That area extends up to about one crosscut pannel above the second reef diamond. (It would be the third reef point if you counted the luff reef point at the mast).
Physical condition.
I had a local loft repair two holes (UV damage or flex damage?) just behind the leach. The patches are about 3" on a side. Also repaired the bottm leach cover where the topping lift rubbed through. That local loft was non-committal when I asked about remaining life.
The rest of the cover has somewhat deteriorated fibers at the places where the leach of the sail folds (stored on the boom).
paulmcquillan is offline
