SailNet Community - View Single Post - Sailing Cat-Litter Box....
post #4 of Old 07-02-2008
artbyjody
artbyjody's Avatar
If you use, 3/4 mixture of sand, 1/4 mixture of cat litter (this is because the cat is trained for that smell) cover that with astro turf..astro will leak through but typically not leak back up the odors, and it gives the cat something to scratch into afterward... the poo is easily gotten to and discarded - and docking days you can flush the mixture with fresh water most of the time and not have to constantly stock cat litter or sand...if you still get a smell - then before laying the mixture described above put down an even layer of charcoal (used for fish ponds) at the bottom before applying the mix and turf. you'll never know you have a cat onboard...
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
