SailNet Community - View Single Post - Perkins 4-108 oil pressure
Old 07-04-2008
BillStewart BillStewart is offline
BillStewart is on a distinguished road
You need to check the oil cooler. Possibly you could run for a while without it if you only use low revs. ( just connect the flex hoses together - and the cooling pipe). I have a friend who's cooler broke - it took 4 seconds to dump all the oil... Mine is showing a bit of contamination in the pipe between the cooler and the gearbox (TMP) but not on the output from the g/box??? I will be stripping it this winter. Good luck.
