SailNet Community - View Single Post - washer for keel bolts
post #8 of Old 07-05-2008
ericroline
Santana 525 PRESTO
ericroline's Avatar
Stainless has a weakness in saltwater for pit corrosion, where the ions setup a cell and eat away if there is a lack of O2 to form the protective oxide layer.
If you are going to the trouble and suspect any possibility, seperate, inspect and rebed the hull-keel joint. I used dry film lube on the studs to prevent gauling during the torquing. Lubing the threads also changes the clamp load to torque by modifing the rotational friction.
ericroline is offline
