SailNet Community - View Single Post - ST-60 Depth - The Answer is YES !!!
post #5 of Old 07-06-2008 Thread Starter
Maine Sail
Maine Sail's Avatar
Halekai-
I mentioned this idea a while back. I used the Raymarine ST60 transducers with the TackTick hull transmitter. The reason this generally works is that Airmar is often the OEM for both instrument manufacturers, and the transducers are basically the exact same except for the packaging.
And Raymarine trys to confuse you by adding a "third rail" or "third wire" which is nothing more than the shielding of the transducer wire..
I will eventually install the new Airmar transducer but for now I'm going sailing... Oh wait? After I replace all the Quest Pex domestic water plumbing connections that are leaking... I can see why there was a class action over these POS Quest Pex fittings.. Time to re-plumb..
______
-Maine Sail / CS-36T
Maine Sail is offline
