SailNet Community - View Single Post - Gearshift in neutral or foward
post #5 of Old 07-07-2008
Senior Mumble
jbondy's Avatar
Yanmar recommends reverse. The transmission is cooled by water circulated when the engine is on. If the transmission is left in neutral when under sail, the spining prop/shaft will cause some transmission parts spin without benefit of this coolant. Not a good thing. And, as you may be experiencing, the spinning prop shaft will allow some water to come in through the packing gland, but this should be minimal.
jbondy is offline
