Old 10-01-2003
sailingfool sailingfool is offline
ASA and PSIA Instructor
PHRF Interpretation
You have the number mechanics down correctly, but some clarifications may help. First higher numbers per se are not generally preferable to low, what a racer wishes for is a boat that will sail faster than its rating - which is hard to find since the rating is purely subjective, based on the opinions of a board of very experienced racers. If a boat SEEMS faster than its rating, then they simply give it a lower number until the preception goes away. What a serious racer should want is a boat that sails well to its rating, whether high or low.
Line honors go to the first-to-finish boats, ratings being ignored. Handicap honors go to boats wining based on their times adjusted by their ratings.
You don''t need to buy a maxi boat to get into negative numbers, in New England a Farr 36 can get you to 0.
