  #86 (permalink)
Old 07-08-2008
Sabreman's Avatar
Sabreman Sabreman is offline
Sabreman will become famous soon enough
I re-rigged Victoria and simply replaced all lines with new. Replaced the wire-rope halyards with all Sta-SetX and they work great. I didn't modify anything that Sabre laid out except to add a 6" wire to boom end of the Vang to keep it away from the mainsheet.
The ratio on the main is fine with me because I'm trimming with a winch. IMHO a 38' (or 34') boat exerts too much strain to even think about trimming by hand.
The vang adjustment is way under-powered. Rather than adding more blocks, I'm going with a rigid Garhauer vang.
Garhauer Marine Hardware -7246260
My halyards are midships. I'd rather that they be farther aft, but I'm not changing it because a) it will really crowd the companionway area, b) I don't want anymore holes in the deck and c) once the jib goes up in the spring, it stays up until fall so having the halyard out of the way (midships) is actually a plus. I just don't want an extra halyard (the main) in the cockpit.
I'm keeping the pole lift/downhaul on the mast because in a race situation, it's the bow man's job anyway & I don't want the extra lines crowding my cockpit. I'd recommend leaving them on the mast using the logic that if you're so short handed that you can't afford to send someone forward to tend the pole or if it's blowing so hard that you don't want someone to go forward, then the spinnaker shouldn't be up anyway. Just my humble opinion
Good luck - you'll save a bundle doing the re-rig yourself. I assume that you'll be doing all the splicing yourself.
BTW - My centerboard is now stuck. Lowered it to check the cable and jammed it by cranking up too hard. Rigged the centerboard un-sticker but it didn't work even after some taps with a hammer. Will try again later at the dock.
Sabre 38 "Victoria"
