SailNet Community - View Single Post - Prop/Prop-Shaft Key Size?
post #2 of Old 07-09-2008
Rockter
The prop will almost certainly be on a taper, and will have a Woodruffe (spelling?) key between taper and prop. A Woodruffe is like a wee half-moon key the curved side of which will be embedded into the shaft, and the flat size keyed to the prop. I can't see a way of knowing what size the key is beforehand.
Do you have a tidal range you can use to your advantage? It would be easier that way.
Rockter is offline
