SailNet Community - View Single Post - Replacing license number from the hull
Old 07-09-2008
chucklesR's Avatar
chucklesR chucklesR is offline
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Acetone should take the stickers off, most registration numbers are stickers.
If what you are refering to is the US documentation number (starts with NO. and then numbers only, inside the boat, permanently affixed) you'll have a harder time removing them as they are supposed to affixed so that remove is obvious).
Acetone is available at most hardware chain stores.
If you can't get acetone use a razor and scape them off carefully. Painting over them will be ugly and not seaman like.
