SailNet Community - View Single Post - Battery Charging . . . again !!
post #9 of Old 07-11-2008
Rockter
I use one one charger and one 3-step regulator, and switch manually. Protect your alternator diodes with a battery master designed to disable the alternator field wire before you switch.
It is simple and it works fine.
Battery internal RESISTANCE determines the battery draw when charging. A discharged battery has less resistance, and so draws more current, slowly falling off as the battery resistance recovers.
Rockter is offline
