SailNet Community - View Single Post - stiff shifter cable
Old 07-11-2008
compac233 compac233 is offline
compac233 is on a distinguished road
Shifting cable
I had a similar problem, until cable connector broke while out on a sail. Nothing like pulling into your slip without reverse!
The push/pull pin had corroded and froze, so that it was bending the cable as I'd shift. After a while it weakened and broke. Look at the pin / connector to make sure it's smooth.
