SailNet Community - View Single Post - I want to fire a flare
post #10 of Old 07-14-2008
sailingdog
Wind_magic-
Unfortunately, Max-on is correct in what he said. The USCG-approved hand flares tend to drop hot slag. The SOLAS-approved ones do not. SOLAS parachute flares may burn up to 60-90 seconds, and can travel quite a distance.
If you really need to fire off a flare, the white ones can be fired off fairly safely, as they are not generally used for emergencies. Get the same brand as the red handheld flares that you'd normally use. For parachute or meteor flares, it is a bit more difficult, due to the greater visibility these have.
A safety seminar, with hands-on section, is probably the safest way to go.
sailingdog is offline
