SailNet Community - View Single Post - Monohull v Cat
Thread: Monohull v Cat
post #2 of Old 07-18-2008
sailingdog
It would help if you said what kind of sailing you intend to be doing. IF you're just coastal cruising and island hopping, a catamaran might very well be a better choice.
Also, what is your budget??
Some Pros and Cons of a Catamaran:
Pros:
  • More living space than a comparable LOA monohull
  • More privacy for living aboard
  • Easier to live aboard since the boat stays level—doesn't heel
  • Often easier to maneuver than monohulls—especially those with twin engines
  • Shallower draft, means you can explore more areas—also good for hiding from hurricanes
Cons:
  • Some catamarans have poor sailing characteristics
  • Catamarans are weight sensitive
  • Catamarans require different sailing techniques than monohulls.
  • Harder to find dock or slip space
  • Some have more equipment (two engines) and more maintenance costs
I hope this helps...
sailingdog is offline
