Singlehanding
Perhaps this might help refocus:
I am a singlehander. I sail a lot so there is often no no else to go with. I have set my boat up accordingly. (Lines led aft)
Always tack from a Close Reach (not close hauled)
When I tack, this is the sequence (from Starboard Tack to Port Tack):
First I tighten the Starboard Sheet and take 1 turn around the Starboard winch
Then I take all turns possible off the Port Winch and hold the Port sheet in my hand
Then I tack the helm to just short of a beam reach
I wait until just after the Jib backwinds, this helps pull the Bow around and keeps me from falling into Irons. It also keeps the jib from flogging and injuring itself.
I throw off the Port sheet and immediately pull in the Starboard Sheet as the sail comes through the foretriangle.
Since I already have one turn on the winch, as soon as the sail starts to draw, it won't pull me overboard.
I take more wraps around the winch and crank it in to proper trim.
I then go to my intended heading and trim the sails accordingly; Jib first then the main.
Very little flogging if any.
Hope that helps.
Smooth Seas,
Don
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Smooth Seas,
Captain Don Quackenbush
SV HERMES, Pearson 33
East Coast, Great Lakes
