SailNet Community - View Single Post - Do Oberdorfer Pumps self Prime?
post #2 of Old 07-19-2008
deniseO30
One of None
deniseO30's Avatar
Last Year I went through just what your experiancing! I have the same engine and pump. yes the pump wll self prime. I found the problem was the gasket between the cover and housing is very thin, The PO had used carboard or something, I tried gasket paper.. too thick also. Finally I got wise and got the right gasket from a nearby ships store. I also got a new cover plate. That fixed it!
A few things I learned:
Make sure you remove the impeller by removing the little snap ring first. If you pull the shaft out it will be easy to change the impeller but you will ruin the seal on the back of the shaft. Then you need to replace that too. (you should anyway) Also, while your working in the system. ck the anti-siphon loop. Mine was open and water was by-passing the muffler. Featherman diesel sells the new pumps with an o ring instead of a gasket. a great idea!
You will find the pump pulls the water right up the hose from the bottom of the boat through the strainer with no priming necessary. (you do have a strainer on the intake.. right?)
good luck hope this helps!
My last project!
deniseO30 is offline
