Old 07-20-2008
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
kaakre...3M only lists mechanical means for removal after curing. Razor blades, putty knives and sanding. If you get most of it off with a blade you might try some very fine (400-600 grit) wet sanding for the remainder but try this on a small area first as the lexan is easily dmaged.
