Old 07-20-2008
parttimesailor parttimesailor is offline
parttimesailor is on a distinguished road
Originally Posted by camaraderie View Post
kaakre...3M only lists mechanical means for removal after curing. Razor blades, putty knives and sanding. If you get most of it off with a blade you might try some very fine (400-600 grit) wet sanding for the remainder but try this on a small area first as the lexan is easily dmaged.
I think almost any abrasives or tools are likely to leave marks in the LEXAN.
Chris
