SailNet Community - View Single Post - routing outhaul and topping lift
post #2 of Old 07-21-2008
sailingdog
Yes, you should be able to re-design the system so that you can run the outhaul and topping lift to the cockpit. Do you have photos of the current system, since that would make it far easier to understand what you've got to deal with to begin with, and how it needs to be modified. BTW, most outhauls have an internal block and tackle in the boom, which can often be removed if you're leading the lines aft to a winch.
sailingdog is offline
