Old 10-16-2003
obiec obiec is offline
obiec is on a distinguished road
Jeff and all the outher realy smart guys and galls
You sound like you have been around a lot of boats I was hopping to pick your brain on a problem. The Ingrid 38 is a double ender full keel as you already know. There are some specks for it at this web address. http://hood.hctc.com/~esteve/ I have re powered this boat with a new 43 hp vetas diesel engine. And one thing that it dose and the other did as well is it will growl at different rpms. But not always the same RPMs. I have replaced the packing and that was not it. Could it be the cutlass Bering.
But that is not my real question . My real question is. Under power the back of the boat will start to squat. At around 1,700 RPMs it will drive the back of the boat down around 12 inches in the water and the boat will be doing around 5.5 to 6 kts. And around 2,200 RPMs. It will drive the back down around 2 feet and will see a speed of around 6 to 6.5 kts. And it will be pushing very hard. The engine in these boats the engine is almost flat hardly any drop to the transom where most boats the engine tilts back maybe 7 degrees or more. It is almost like it needs a trim tab on the transom to give it some lift. I think the boat should not start to fight hull speed till it is around 6 kts. But I think this boat starts to just after Idle or 1,000 RPMS. I don’t suppose prop size would help would it.
