SailNet Community - View Single Post - routing outhaul and topping lift
post #8 of Old 07-22-2008
sailingdog
Chuckles-
You should probably ease the outhaul when you're have the main sail down, since it may stretch out the foot of the sail a bit otherwise.
You generally need to tension the outhaul more if you're sailing in heavier winds, ease it a bit when sailing in lighter winds. Tensioning the outhaul makes the sail flatter...easing it gives the sail a bit more power by making it fuller.
One of the main reasons I led my outhaul aft was to have better control over the main sail's shape. I regularly sail in SCA type weather, and being able to flatten the main helps a lot. Also, the two-to-one tackle in the boom really didn't give me enough leverage on the outhaul... now I have an ST40 winch to use. Much easier to adjust the tension.
sailingdog is offline
