Hatch gasket material
Thanks for your reply re. the hatch gaskets. I also have the bronze hatches. Hull # 24. Did you change the acrylic because of leaking or cracking? Mine are scatched up fairly badly but do not leak. Only the gaskets. Is the portlight rubber you mentioned the gasket material and do you know a source for this. And lastly do you remember approximately the cost of doing all three hatches. We will actually be coming through Ft. Lauderdale in a about a month or so. Thanks very much for your help.
