  #11 (permalink)
Old 07-23-2008
Maine Sail's Avatar
Maine Sail Maine Sail is offline
Jim,
The clamps on the other page are likely AWAB hose clamps and they are all I use on my boat. They don't have the perforations in the band but rather stamped gears and as such are much more reliable. Is your thru-hull 1/2"?
I really prefer the "sweep" elbows as in the full flow ones you showed. They are easier to snake and will also plug up less frequently than a regular "tight turn" 90 degree elbow..
If I can get down to Hamilton today, I need to, I will screw some fittings together with the strainer and write down the PN's for you..
______
-Maine Sail / CS-36T
