Multi vs Mono
The advice given thusfar is excellent. I would only add that (depending on your budget) a monohull in the high 30'' to low 40'' range may be quite manageable by a couple and can even be singlehanded if it''s equiped with suitable lifting and sailing aids.
Boats with electric winches and an electric windlass can easily be sailed by even a 98# weak-link. Furling headsails and furling mainsails are no longer uncommon, and there are some that are motor-furled.
Of course, having more electrical equipment requires a greater electrical supply and capacity. However, a large boat can easily carry more batteries, and will likely have the room needed for solar panels and/or a wind generator, etc.
Important reasons for getting a large boat are: comfort, storage capacity, tankerage for water and fuel, and sturdiness. In many ways you''re in luck. There are many boats (new and used) in the size range mentioned that are (or could be made to be) well suited for extended offshore cruising. They will likely cost more to setup for ease of sailing, but if the sailing aids make sailing easier and more pleasurable, then the investment will be well worth it.
~ Happy sails to you ~ _/) ~
