SailNet Community - View Single Post - Recommended cruising boats
  #12 (permalink)
Old 10-20-2003
Jeff_H's Avatar
Jeff_H Jeff_H is online now
Super Moderator
Jack, with all due respect, I believe that you and I are talking about two different models. The Hunter that I am refering to had a partial skeg hung rudder and a beefy hull deck joint consisting of an aluminum toe rail closely bolted through the deck and a wide, thick inward facing flange. These boats appear to be pretty close in quality to the Brewer designed Morgan 38 although you might be right that the Brewer has a potentially more robust skeg hung rudder.
Respectfully,
