SailNet Community - View Single Post - If you don't know how to anchor... DON'T !!!!!!
post #118 of Old 07-24-2008
SVAuspicious
Mermaid Hunter
SVAuspicious's Avatar
dquack -
Look up your boat length and displacement on the Rocna sizing chart - take the larger of the two and you should be set. Unlike most sizing charts, there is no need to go up a size from the recommended anchor. My boat (just under 41', just over 22000 lbs) has plenty of anchor with a Rocna 25.
Note that a "tonne" is a metric ton, 1000 kg or about the same as a long ton (2240 lbs).
SVAuspicious is offline
