SailNet Community - View Single Post - New Throttle Cable
post #4 of Old 07-24-2008
djodenda
djodenda's Avatar
On reviewing my post, I realized I wasn't being completely accurate
If you are changing holes at the pedestal, moving the cable CLOSER to the pivot will increase the lever travel from idle to full throttle. (what you want)
If you are changing holes at the engine, moving the cable AWAY from the pivot will increase the lever travel from idle to full throttle. (what you want)
Careful examination of the levers should reveal, by wear patterns where the cable really was attached.
Sorry about that. Good luck, and let us know how things work out.
David
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
