SailNet Community - View Single Post - hot water from the boat engine
post #7 of Old 10-20-2003
kimberlite
i bled the system by opening the overpressure valve on the fresh water side and just let the engine circulate the water until the air was bled out of the ststem. if your tang is highte than the engine you might have to add a bleeed valve to the coil side of the heater.
my engine takes about 30 minutes to heat 12 gallons of water to 180 degrees.
fair winds,
eric
kimberlite is offline
