SailNet Community - View Single Post - lightning protection
post #2 of Old 07-28-2008
sailingdog
I wouldn't recommend grounding the boat. There are two schools of thought on this...
The first is that you should bond and ground the boat. While some think this reduces the severity of damage in the case of a lightning strike, it is also thought to increase the chances of your boat getting struck.
The second is that you shouldn't bond or ground the mast/shrouds/etc. While some think this reduces your chance of getting hit, others believe that it will result in greater damage if you are hit.
Basically, if you're happy with the way your boat is... leave it alone.
sailingdog is offline
