SailNet Community - View Single Post - ablative or hard bottom paint?
post #8 of Old 07-29-2008
artbyjody
artbyjody's Avatar
Unless you have the opportunity to hit fresh water all the time... I'd have to say hard is the way to go if you are the racing type - at least then you can hire a diver to scrape off the muck before ... soft ablatives are good as well, but scrubbing the bottom takes off that protective layer each time.
Now if you can go into fresh water at certain intervals, then you can balance the costs.. then again if you are just cruising versus racing that accounts for the decision as well. You'll still spend $$$ regardless - how much is determined by the area of water you are in and the ability to reach other areas of water (ie: fresh versus salt), and how hardcore a sailor you are in terms of performance...
Generally speaking for most, ablatives are cheaper overall unless you are about speed, then hard is the way to go.
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
